Brief Description: Deburring right wing rib to spar attaching holes
After having match drilled the right wing rib to spar attaching holes I disassembled the right wing skeleton and deburred all the holes. I also made the holes in the ribs for the wiring conduit. I finished by engraving each rib with its relative position from inboard to outboard to make identification and reassembly easier.
